Hi Florian,
I must be using up my credit for the enhancements being suggested...
OK, my working practise is as follows:
- Retag
- Tag->Filename
Simple enough, except when I want to place the files in different folders in this working session.
For example:
for real artists I want to choose the "x:\Music\Artists" Folder
for various artists I want to use the "x:\Music\Various" Folder
and for everthing that cannot be matched I want to use the "x:\Music$$$NoMatch" Folder
Based on my working practice I have to continuously edit the Tag->FileName Format String...painful
I am thinking that the Tag-Filename Dialog could be modified to be a table of say MAX 5 entries with a radio button to allow selection of the now "permanent" Tag-FileName format string.
The radio button would of course have to be "session bound" that is fixed selection until changed and then changed back....if that makes sense.
I do not think a dropdown list work work in this instance as it means too many "finger clicks"...therefore this should not be countenanced.
Thoughts from others also appreciated.
PS - can you make the box wider - it's a pain having to home/end the textbox to find out where you are especially with all the scripting functions in the format...
I Know it is designed for people with "640" screens but for those of us with 1024 or 1280 screens it is a real pain...maybe screen resolution should be a selected option (or programmed) allowing the appropriate box sizing for screen resolution.
With kindest regards
and keep up the excellent work...
Sean
