Tag Panel only allows capital letter tags
I am trying to create a custom tag in many flac albums. I have set a column on the RHS of MP3tag listing and it works perfectly. It sets the tag name to DateOfEntry just as intended for individual tracks. However, if I wish to use that from the tag panel on the LHS to set the same tag for all tracks in the album it seems to only allow a setup using capital letters only.
I’m quite sure I’m misunderstanding this but can’t figure it out. Could anyone enlighten me please?
Thanks, Bob.
If you really want to use the syntax DateOfEntry, then you can manually edit the according Tag Panel .ini file in the configuration folder of Mp3tag.
Thank you. I’ve had a go at this. :grinning_face: Eventually, I found a file configuration folder \ data \ usrfields.ini and in it I found DATEOFENTRY. I changed it to DateOfEntry and saved it.
Wow, it only works !!:slightly_smiling_face:
Thank you very much.
Cheers, Bob.
