Oblio
1
Could the tag boxes also be made to resize with the panel. At the moment when you stretch or shrink the panel out they stay the same size. Thanks.
Edit:
Actually they do resize normally but that stops working if you change/update the tag panel in File - Options so that makes this a bug report!
the tag panel in Tools
Not reproduced here - V2.39i. E.g.
- In Tools Options Tag Panel add a field
- In the main window, drag the divider away from the tag panel
- See that tag panel fields do enlarge as desired.
Oblio
3
Just upgraded to 2.39i but same problem exists. Try editing a field, not just adding one.
Oblio
4
Mmm thats strange. This is still an issue for me in 2.39j and reproducible on 2 PCs. Any update to the tag panel stops the fields resizing.
Why would I be seeing this and chrisjj not? Anyone else able to reproduce?
chrisjj
5
Reproduced here! As you say, the field resize stops working.
Florian
6
I can also reproduce it but have no idea to fix it at the moment. It's kinda low priority.
