Tag Question for Nero AAC Files
I'm using version 2.30 of Mp3tag. When I add tags to Nero AAC files (filename.aac) Winamp 5.80e will not display them. I can see them with Mp3tag. If I use an another tag program I can see the tags in Winamp as ID3 V2 type. Any idea whats going on?
Do you have MP4 input plugin for Winamp?
http://www.rarewares.org/mp4.html
There is an existing mp4 plugin in Winamp that reads the tags created with the other program. I tried the Rareware version just to see, no joy.
If I am not mistaken, MP3Tag can only write ID3v1 and APEv2 tags to AAC files. Maybe your Winamp plugins support only ID3v2. :unsure:
Writing ID3v2 tags to pure AAC files is a bad idea IMO. Since AAC simply has no standardized tag format, you should wrap them in a MP4 container instead.
Best regards,
~ Florian
The Winamp plugins support ID3v1 and APEv2 as well. But if there is no standard then see below...
I was using AAC format because HE AAC mp4/m4as would not play in Winamp. But now that I have found the Rarewares in_mp4.dll (Thanks to dano in the earlier post.) I will use the mp4/m4a container now.
