Tag remove problems
I've been having problems removing tags. can you make it faster and better to remove and replace the tags.
Could you elaborate what your problems are? You say that you have problems but you don't say how to identify or reproduce them.
So please shed some light on it.
It’s moving really slow and not removing the tags from episode and not allowing me to add artwork afterwards like for example I want to remove Echoes of the Mind 1 etc photo and remove the episodes thumbnail and save after in one go poster from universal. See link for example
So apparently you are modifying video files, which are, I assume, fairly big.
Depending on the extent of the tag changes, the file has to be rewritten completely. This may take some time, depending on the hardware environment.
Where do you see the thumbnails? In Mp3tag? Does MP3tag show the pictures as you intend them to be?
All I see is the dumb episode tag not poster so I end up waiting for mp3 tag to remove the episodes tag in order to add poster
Does this refer to the program MP3tag or to your player?
What kind of files do you treat?
So I use dvdfab it pulls the episodes tag no poster so if I just save it makes a funny double picture so I have learned that have to remove each individual tags but it takes long time to remove and then I have to save the poster is there a faster way to get this done
I use Mp4 files at fastest speed
As I said: depending on the size of the modification and the already present padding (I haven't said that yet) the file may have to be rewritten.
The consumed time depends a lot on the file size and the writing speed of your data storage.
The worst solution for that is: big files on a network drive connect via a WAN connection.
The best would be to have an internal SSD as storage.
Also, it could be an idea to add and remove the pictures in one step with the extended tags dialogue, where you can save all the modifications by clicking OK.
Yes I was afraid of that thanks I’ll just be patient and deal with it how it is currently hopefully future updates the developer would ask do you want remove and replace with picture you added
If you import a picture with an action then you can already set that existing covers get replaced.
Only if you use the interactive way, you have to do it step by step.
Can I get some pictures on how to do this
My descriptions will probably not be better than the FAqs and HowTos.
So please there on howto create a new action
and the action "Import cover from file"
Ok all go YouTube see if they instructions and then question and answer
