In previous versions I could enter default values in the tags.
In the new version this isn't possible and that's what I always used to give some tracks
my own album-name.
I have stil got older setups of Mp3tag but when I install these the links to Discogs doesn't work.
The message I get:
Failed to authenticate using OAuth (1).
12029:12029: Can't establish connection with the server.
Is there a possibility that this function can be re-introduced in the next update?
Or is there a new place in the settings menu?
If so, I can't find it.
I'm a new poster here so I was glad to find this question as I thought I was losing it when I couldn't find this setting since updating the app in August. I just downloaded an older version of MP3Tag so I can set tag defaults as I find it a real time saver. Sadly, I don't like the duplication in the tag panel in this older version.
Any chance of restoring the tag default settings and shortening the tag panel like the newer versions?
