According to this post:
/t/964/1
upgrading mp3tag should preserve my previous settings.
However, after upgrading from v2.59 to v2.60 all of my tag sources were disabled (greyed out).
I then saw that there is already 2.61, so I upgraded again, but still no joy.
How can I get my tag sources back?
They're only enabled if you also select files to apply them on.
Can you try that?
Kind regards
Florian
;-} Now I feel very stupid! That was it; thanks for the prompt and helpful answer!
Thanks also for the new version (2.61a)!
No problem, glad that it works now
