Tag to Foldername possible?
My new radio omits the album tag, which is f.ex. 1999 - Album1, and instead uses the normal folder name, which only is Album1, no year preceding.
I would like to change all my folder names, so that they would exactly look like the album tag meaning 1999 - Album1.
Is that possible?
Thanks.
This has been answered in the FAQs, see here:
Ok, I found exactly that thread before posting my question as I don't have the slightest idea what to do to get it like I want. Their example doesn't help.
I need to change the folder name, not the filename, thus I would need a tag - foldername option.
Use an action of the type "Format value" for _DIRECTORY
Format string: %album%
Great, that actually works, many thanks to you, you saved a lot of my grey cells.
