I expect this is me being dumb but I am struggling to tag using MusicBrainz on a double CD.
It finds what appears to be a match but the song list offered is both CDs and I want just the second CDs data as I have done CD1, I don't seem to be able to 'get' just that. The only solution I can think of is to combine the files of both CDs and then tag, which seems a bit clumsy!
Thanks
If you select fewer files than that what is offered by the Musicbrainz Query, then you should be able to move the files in the list on the right to align them with the corresponding MB data on the left.
The question is always: what data does the source (here: Musicbrainz) supply for the query that you have started.
As @ohrenkino wrote:
@peterb You can do this for multiple selected tracks at once or for every track individually:
