i have a little problem, not sure if it is a bug or has gone unoticed thus far. Before i start however, i want to express how fantastic this program is, it is the one stop solution to tagging all my MP3's that i have searched long and hard for.... so kuddos.
uI have been using the search for a tag for my song using amazon option. When it finds the correct album and artist I then select the correct song from the list it brings up. I am assuming that after i select the song it then exports all the tag info to the mp3 tag. What it actually is doing is inserting everything but the song title correctly, instead of inserting the selected song it simply picks the first song from the list under the particular album in amazon.
eg.
my song,
ac/dc - razor's edge
it will import
ac/dc - razor's edge and tag artist:ac/dc title:thuderstruck album: razor's edge
can someone tell me how to fix this?
thanks in advance
fod
