Tagging specific Classical Album with the help of web source
I searched but could not find anything describing my issue. I have a classical (digital) album I'm trying to correctly tag. I've tried musicbrainz as well as Discogs but no luck. I can't figure out the correct Artist & Title to enter in order to get a match in musicbrainz or discogs for that matter. This is the title - see attachment. Thanks for looking
I found it at Musicbrainz with "Symphonien Nr. 40 - Nr. 41", Artist "Karl Böhm"
Thanks for that, that's helpful but I believe I found that one or one similar. That said, the issue is that your version and the one I found only list 8 tracks, the digital version I have is 28 tracks! That's also part of my difficulty matching it up.
A good idea my be to locate the album on the web site itself and use the release id
Ok thank you. Good idea, hadn't occurred to me to search the release ID.
Ok, believe I've got it sorted now thanks for the help
