Hi guys,
I haven't used mp3tag for a quite long time. Now, I have realized that discogs changed its API again, so I can't tag my mp3s with a custom made script anymore, which searches the discogs database based on the release ID number.
I tried to adjust the discogs.scr file (within the newest mp3tag version 2.96), but it doesnt work.
Could you maybe help me out how to modify the file for my purpose??
I have attached a screenshot of a release, and marked its unique ID number, which I want to use as the search parameter inside mp3tag
There is a discogs script that uses an ID ...
/t/9226/1
thanks! I will take a look at this.
Danke!
Simply change the following settings in the discogs.src:
[IndexUrl]=http://api.discogs.com/database/search?release_id=%s
[SearchBy]=%id%
I'm stuck/confused. Help! I implemented this change, except instead of modifying the original .src, I saved the changed as discogsbyid.src
The new .src shows up in the MP3Tag menu, but when I try to use it I get 401 UNAUTHORIZED.
If I try the original .src it works but not using the ID. I'm sure I've done something wrong, but what ?
