Hi! I am new using Mp3tag but I like using it a lot.
Only one question:
I was using the converter Taglist-file to Tag for a whole day and I was not able to get it runs properly. I tried exporting tags to csv and txt, after I only changed several characters for a track and after I tried to import the taglist-file but nothing changed. I was very mticulous checking the formatstring.
Anybody can help with an example how I can use the import tags via the converter Taglist-file - Tag.
Thanks Sebastian,
But I had just followed the steps you told me and with the formatstring you noted in your answer. Perhaps I might to explain more concisely my problem.
I have the following file:
And the formatstring is:
When the filename (01 [Wassermusik] Ouverture.mp3) appears into tha taglist-file that field is no recognized and is not changed in the column called filename.
However, whether filename is deleted in the taglist-file, the remaining fields are imported as I previously proved and you indicated in your reply.
Another thing I've tried also to use only the filename without extension (01 [Wassermusik] Ouverture) using properly %_filename% in the formatstring but it doesn't run.
I have this proble now, have been using it and then it has stop converting. dosn't want to read and save the data.
Howard Shore - The London Philharmonic Orchestra / Lord of the Rings: The Two Towers / Soundtrack / 2002 / Howard Shore - Reprise / 01 / 01 - The Prophecy.mp3
etc ..
For me, it works perfect, even with
%artist% / %album% / %genre% / %year% / %copyright% / %track% / %title%
Which version of Mp3Tag do you use?
Have you tryed the newest developer build?
