Hoping there is a simple solution,
I sometimes get my music from dirpy/youtube or from jukeboxes with realplayer, then I update the tags with mp3tag before copying to my Zune folder for syncing. I noticed that the tags for wma type files are not showing correctly after copying to Zune, However file types mp4 or mp3 work fine. Can I convert the wma files to mp4? Or Is there a setting that I need to set differently in MP3tag?
Update,,,
while searching the web after posting,, I found this:
http://zunerama.com/forum/index.php?topic=7842.0
I will follow the instructions and post back what I find,,
thanks.
