Thank you
Been looking for a freedb tool that will help me label tracks of ripped cassettes. This is the best I've found so far -- thank you! (Probably worth more than the 8 euros I donated.)
Only way it could be better is to allow me to select a block of tracks, and assume that tracks are in the same order as CD. (As freedb doesn't have track length, right?)
Hi John,
first of all, thank you for the donation! It's much appreciated :slight_smile:
Mp3tag already assumes that tracks are in the same order as on the CD. If you want to rearrange them, you can do it via drag&drop while holding the [Alt] key down.
Best regards,
~ Florian
