Title Case for Selected Fields
I know that this was discussed way back in 2011 and 2014, but I'm not sure if any sort of solution was found. I'd like to be able to convert song names, album names, and possibly artists (or other fields chosen by the user?) to English title case (e.g., Snow White and the Seven Dwarfs). Below is a script to do so from another app that isn't as fully-functioned (or easy to use) as mp3tag. Could something like this be enabled as an option within mp3tag?
// This script capitalize your tag value with the capitalization rules from the common English title case style ("a day in the life" -> "A Day in the Life")
using System;
using System.Collections.Generic;
using System.Globalization;
using System.Linq;
using Metatogger.Data;
 // enter tags name to process => eg. { "TAGNAME1", "TAGNAME2", TagName.TrackNumber }
 // leave the array empty to process all tags => { }
string[] tagsToProcess = {  };
public static class EnglishTitleCapitalizer
	public readonly static string[] Prepositions = new[] { "about", "above", "across", "after", "against", "along", "among", "around", "at", "before", "behind", "below", "beneath", "beside", "between", "beyond", "but", "by", "despite", "down", "during", "except", "for", "from", "in", "inside", "into", "like", "near", "of", "off", "on", "onto", "out", "outside", "over", "past", "per", "since", "through", "throughout", "till", "to", "toward", "under", "underneath", "until", "up", "upon", "via", "with", "within", "without", "versus" };
	public readonly static string[] Articles = new[] { "a", "an", "the" };
	public readonly static string[] Conjunctions = new[] { "and", "but", "or", "nor", "for", "yet", "so" };
	public readonly static char[] EndingPunctuations = new[] { '.', '?', '!', ':' };
	public readonly static HashSet<string> MustBeUpperCase = new HashSet<string>(StringComparer.InvariantCultureIgnoreCase) { "I", "II", "III", "IV", "V", "VI", "VII", "VIII", "IX", "X", "XI", "XII", "DJ", "MC", "TV", "MTV", "EP", "LP", "YMCA", "NYC", "NY", "USSR", "USA", "R&B", "BBC", "FM", "AC", "DC", "AC/DC", "UK", "BPM", "OK", "Q&A", "FAQ" };
	public readonly static HashSet<string> MustBeLowerCase = new HashSet<string>(StringComparer.InvariantCultureIgnoreCase) { "ft", "ft.", "feat", "feat.", "n'", "'n'", "no." };
	public readonly static HashSet<string> TheGroups = new HashSet<string>(StringComparer.InvariantCultureIgnoreCase) { "Beatles", "Police", "Corrs", "Doors", "Beach Boys" };
	public readonly static Dictionary<string, string> SpecialMixedCase = new Dictionary<string, string>(StringComparer.InvariantCultureIgnoreCase)
		["rock'n'roll"] = "Rock 'n' Roll",
		["o'clock"] = "O'Clock",
		["djs"] = "DJs"
	private static int GetFirstCharIndex(string s)
		for (int i = 0; i < s.Length; i++)
			if (Char.IsLetterOrDigit(s[i]))
				return i;
		return -1;
	private static int GetLastCharIndex(string s)
		for (int i = s.Length - 1; i >= 0; i--)
				return i;
		return -1;
	private static string GetWordCore(string s)
		int firstCharIndex = GetFirstCharIndex(s);
		if (firstCharIndex == -1)
			return s;
		return s.Substring(firstCharIndex, GetLastCharIndex(s) + 1 - firstCharIndex);
	private static string UpperCase(string s)
			return s;
		if (SpecialMixedCase.ContainsKey(s))
			return SpecialMixedCase[s];
		var sb = s.ToCharArray();
		sb[firstCharIndex] = Char.ToUpper(sb[firstCharIndex]);
		for (int i = 0; i < sb.Length - 1; i++)
			if (Char.GetUnicodeCategory(sb[i]) == UnicodeCategory.DashPunctuation)
				sb[i + 1] = Char.ToUpper(sb[i + 1]);
		return new string(sb);
	public static string Capitalize(string title, bool resetUpperCase = false, bool useTitleCase = true, int maxPrepositionLength = 3)
		if (String.IsNullOrWhiteSpace(title))
			return null;
		var lowerCaseWords = new HashSet<string>(StringComparer.InvariantCultureIgnoreCase);
		if (useTitleCase)
			lowerCaseWords.UnionWith(Prepositions.Where(word => word.Length <= maxPrepositionLength));
			lowerCaseWords.UnionWith(Articles.Where(word => word.Length <= maxPrepositionLength));
			lowerCaseWords.UnionWith(Conjunctions.Where(word => word.Length <= maxPrepositionLength));
		if (resetUpperCase)
			title = title.ToLower();
		string[] words = title.Split(new[] { ' ' }, StringSplitOptions.RemoveEmptyEntries);
		for (int i = 0; i < words.Length; i++)
			string word = words[i];
			string wordCore = GetWordCore(word);
			if (MustBeUpperCase.Contains(wordCore) || MustBeUpperCase.Contains(word.Replace(".", null)))
				words[i] = word.ToUpper();
			else if (MustBeLowerCase.Contains(word) || MustBeLowerCase.Contains(wordCore))
				words[i] = resetUpperCase ? word : word.ToLower();
			else if (lowerCaseWords.Contains(wordCore)) // the word should be lower case...
				if (i == 0 // ...unless it's the first word
					|| i == words.Length - 1 // ...unless it's the last word
					|| Char.GetUnicodeCategory(word[0]) == UnicodeCategory.OpenPunctuation // ...unless the word begins with '('
					|| word[0] == '"' // ...unless the word begins with '"'
					|| Char.GetUnicodeCategory(word[word.Length - 1]) == UnicodeCategory.ClosePunctuation // ...unless the word ends with ')'
					|| word[word.Length - 1] == '"' // ...unless the word ends with '"'
					|| Char.GetUnicodeCategory(words[i - 1][words[i - 1].Length - 1]) == UnicodeCategory.ClosePunctuation // ...unless the previous word ends with ')'
					|| Char.GetUnicodeCategory(words[i - 1][words[i - 1].Length - 1]) == UnicodeCategory.DashPunctuation // ...unless the previous word ends with '-'
					|| EndingPunctuations.Contains(words[i - 1][words[i - 1].Length - 1]) // ...unless the previous word ends with '.'
					|| (String.Equals(wordCore, "The", StringComparison.InvariantCultureIgnoreCase) && TheGroups.Contains(GetWordCore(words[i + 1])))) // ...unless "the" is a part of band's name
					words[i] = UpperCase(word);
				else
			else
		return String.Join(" ", words);
foreach (var file in files)
	foreach (var tag in file.GetAllTags().Where(kvp => tagsToProcess.Length == 0 || tagsToProcess.Contains(kvp.Key)))
		foreach (string tagValue in tag.Value)
			file.SetTagValue(tag.Key, tagValue, EnglishTitleCapitalizer.Capitalize(tagValue));
See here for the grammartron set of actions:
It's the closest currently available.
I wonder how the non-English languages should be detected.
