Hi all,
I'm new to the board and to mp3tag and a complete illiterate when it comes to Regular Expressions so I can't figure this one out...even if it bit me
A lot of my files have this format:
track - artist - title - mix.mp3
or
I'm trying to make them look like this:
track - artist - title (mix).mp3
so, basically, I would like to replace the Title field that looks like this:
title - mix
and make it look like this:
title (mix)
This is extremely basic and yet, I can't figure it out.
Help Please?
Thanks for your help
Seems you only want to work with the TITLE field so use this:
This will only work if the title contains one -
Format action
FIELD: TITLE
FORMAT STR: $if($eql($regexp(%title%,'[^-]+',,),-),$regexp(%title%,(.+?)\s+-\s+(.+),$1 ($2)),%title%)
Which will result in (leaving more than one - chars in the TITLE field untouched):
Title - Mix
Title (Mix)
Title - Other Stuff - Mix
Or you could do this either:
FIELD: TITLE
FORMAT STR: $regexp(%title%,(.+)\s+-\s+(.+),$1 ($2))
Which will result in (using from the last - char):
Title - Mix
Title (Mix)
Title - Other Stuff (Mix)
EDIT: to fix leaving more than two > leaving more than one
