Title name not working for me :(
Hi
after using the Amazon look up i find the results window gives me the tag info, in 2 windows i have the track names - the first set is correct and has the track names, the second just has "Audio track 1" etc i just can't figure out how to apply those looked up track names to the music files but they are being found! any help appreciated!
If you have info in the TITLE of the song then use the TAG to FILENAME conversion using the mask %title% and then try again.
EDIT:
The adjust tag information window only uses the FILENAME. So that's why you need to fill it with the %title% in your case.
