Hi ,
I've numerous titles the look similar to this example :
Make My Dreams Come True (Original Recording Remastered)
I wish to remove the following :
yes I've searched but sadly haven't found anything I can comprehend ...
TIA
btw , I've solved this in a coluted way by using Bulk Rename Utility ( freeware )
https://www.bulkrenameutility.co.uk/Version.php?Version=3.3.1.0
to sort the filenames then mp3tag to transfer filename to tag then using auto number and transferring title back to filename .......
gotta be an easier way .
Using the search words "remove" and "brackets" I found this thread:
Sorry If this is a basic question, but I cannot manage to remove brackets with text inside them. For example, „Titanium (feat. Sia)“. I want it to be only „Titanium“. „Turn Me on (feat. Nicki Minaj)“ I want it to be „Turn Me on“.
OK , revisiting this and sadly the indicated thread does not help .
there appears to be some information missing from the supplied solution and I'm still unable to acheive my objective
I suggested that you use the search function. I did not say that you get a ready-made way but a one of the many ways that in many cases needs a little tweaking.
You may have noticed that your string does not contain "feat."
So leave out the "feat. " if you use the exact example from the linked thread.
