My mp3 file names follow the convention: yymmdd Author {Series} Description
For example: 070603 John Doe {Sunday Morning Series} This is small description.mp3
I have 3000 files. Is there a way where I can use regular expressions to have the Title be the Description of every file. In the example above, the title would be: This is small description
The 'Title' tag should contain a portion of the filename.
Another Example: 070203wABC {Name of Series}XYZ.mp3
XYZ is the 'Title'
The 'Title' should be that which is after the curly brackets.
This should work:
Convert/Filename-Tag
Formatstring: %DUMMY%} %TITLE%
This should work:
Action #1: Action type:Format value Field:TITLE Formatstring:$regexp(%_filename%,^(.} )(.)$,$2)
This should work:
Action #1: Action type:Format value Field:TITLE Formatstring:$regexp($regexp(%_FILENAME%,.*} ,),.mp3$,)
This should work:
Action #1: Action type:Format value Field:TITLE Formatstring:%_FILENAME%
Action #2: Action type:Replace with regular expression Field:TITLE Regular expression:^(.} )(.)(.mp3)$ Replace matches with:$2
[ ] case-sensitive comparison
The contents of %_FILENAME% seems to be ambigious.
In cases 1, 2 there is no file extension '.mp3' included but in cases 3, 4 there is a file extension.
Thank you for your support. I have studied the regular expressions using the examples shown and have come up with the following that did what I needed:
