I'm new to this but if it works the way I hope it does I'll be really happy. I'm having trouble trying to Change the title to the album for a bunch of songs at once. I am using the tag - tag function but when I try to use it it just removes the title without putting it in the album box. I'd really appreciate some help, thanks.
Unfortunately, you do not tell us how you use it.
To copy the contents of TITLE to ALBUM ...
Select the files
Open Convert>Tag-Tag
Select ALBUM for field
Enter %title% as format string
Click OK.
Well there's my problem! I had them switched
. Thanks A lot for that quick explaination.
