ITPR
March 25, 2015, 6:46pm
1
using tag-filename there are a few characters/symbols that don't show up in filename when the title is imported in itunes files (.m4a)
i have found that when i try to import filenames some symbols don't show up and the missing symbol loses its place in filenames
what i want to do is if a title has a symbol that doesn't transfer e.g' /' i would like it to be replaced simply with a '_'
any help would be appreciated thanks
I think that the simplest way is to use the $validate() function.
Enter your preferred composition of field variables but enclose the whole thing (to be sure) or just the %title% (if you are sure) in the $validate() function:
e.g. $validate(%title%,_)
Alternatively, you can devise your own rules with $replace().
And finally: there are characters for / that look like / but are in fact a different character e.g. ⁄
vkostas
September 1, 2016, 5:52pm
3
ohrenkino:
I have solved my issue with replace.
Original Replacement Unicode nr Unicode hex
/ ⁄ 8260 U+2044
: ː 0720 U+02D0
* • 8226 U+2022
? ‽ 8253 U+203D
" ″ 8243 U+2033
< ‹ 8249 U+2039
> › 8250 U+203A
| │ 9474 U+2502
\ ⁞ 8286 U+205E
Apart from Backslash () and star (*) the replacement are very similar.
Build filename without losing special characters.
$replace(%myTAG%,'/',$char(8260),':',$char(720),'*',$char(8226),'?',$char(8253),'"',$char(8243),
'<',$char(8249),'>',$char(8250),'|',$char(9474),'\\',$char(8286))
Extract info from filename (restore correct characters).
$replace(%myTAG%,$char(8260),'/',$char(720),':',$char(8226),'*',$char(8253),'?',$char(8243),'"',
$char(8249),'<',$char(8250),'>',$char(9474),'|',$char(8286),'\\')
