toggle sound effects?
I can't find the option to control the sound effects used in Mp3tag. These can be quite "alarming" and seem quite loud. Otherwise, Mp3tag is flawless!
Under File>Options>Messages you can check and uncheck prompts that appear.
Unchecking them should help stop heart-attacks.
Either that, or turn your speakers down. Lol.
Thanks! No more hitting the ceiling every time I do a save :smiley:
So MP3TAG is flawless yeh?!
