.i did,but not working in example 1 but in example 2 is name and last name any idea for?
you say:
example 1
Type: Guess values
Source format: %artist% = Rihanna ft. Beenie Man & Bounty Killer
Guessing pattern: %artist% ft. %dummy% = Rihanna ft. Beenie Man & Bounty Killer ft. %dummy%
I don't understand the way you told us your solution.
The action "Guess Values" needs a unique separator which you have with " ft. " (space, Ft., space).
I can see no difference in your 2 examples. Each one is seperated by this seperator and should work with the action I wrote.
Also I don't understand what you mean by 2 steps. There is no need to split by a seperator in a first step. The seperator is part of the action type "Guess Values".
Could it be that you did not write %artist% in your action but the content of the placeholder %artist%?
