I am following the setup steps of the Tools menu to open the selected file in the Wave PadSound Editor software (NCH Software) and I can not. I only have to open the program, but I do not load the song for its edition.
I tested with commands
/ add "% _filename_ext%" and I get a warning that does not find the file but it is
load
play
Help! Thanks!!
hola,
Estoy siguiendo los pasos de configuracion del menu herramientas para abrir el archivo seleccionado en el software Wave PadSound Editor (NCH Software) y no puedo. Solo llevo a abrir el programa, pero no me carga la cancion para su edicion.
He probado con los comandos
/ add "%_filename_ext%" y me sale un aviso que no encuentra el fichero pero si esta
/ load......
/ play....
I don't use this software but I had a look at the website http://help.nchsoftware.com/help/en/wavepa...ommandline.html
and I can not see a parameter "/add".
As far as I understand the ducumentary to open a file it is only necessary to use
wavepad.exe [file(s) to edit]
So it should only be necessary to write "C:\Program Files\NCH Software\WavePad\wavepad.exe" to the path-field and to write %_path% to the parameter-field.
Also there is a remark: "Note: This feature is only available in WavePad Master's Edition."
could you first clearify the exact syntax for a command line call for that program that you intend to use?
You then tell us what it looks like and the forum will most likely help you to map that to a tools call.
The current approach is absolutely pointless as it features only trial and error as technique - and this could go on forever.
