I want to set the path parameter for AAD that will preserve the existing extension. In f2k I'm using: /p "C:\Users\Cristov\Music\Artist Art'%'artist'%'.'%'extension'%'"
What should I use in mp3Tag to ahieve a similar result? Right now I have:
Why do you pass on the extension anyway? And shouldn't this be the extension of the picture file?
If you have a careful look at the aad-syntax it is %extension% whereas the Mp3tag internal variable is %_extension% with an underscore.
So right now you pass the contents of the MP3tag variable to the command line but what you want is the literal string '%extension%'
Have you tried your solution from f2k?
It seems to need to know what extension should be used when saving the file.
I have looked at this and tried the f2k syntax does not work which is why I'm asking for help. The issue seems to be with escaping some of the characters. %extension% should work but it's not being passed to AAD.
