Tools and Tools and more Tools
The is this configurable feature available at
File > Options > Tools
I remember years ago, that this double usage of Tools was confusing for me. And confusion is counterproductive. So I just do not understand why there is such repetition
Thus I propose changing that second Tools to something else. My propositions are:
  • CTRL Shorcuts
  • Additional Tools
  • Stunts
  • User's Aides
  • User's Shorcuts
  • User's Tools
  • User's Utensils
And then also that third usage of Tools, sitting just right above the list containing of them, I propose changing by adding to [whatever name will be chosen] List at its end
A language problem.
In German, it's File>Options>Tools (or actually Datei>Optionen>Tools)
Changing first Tools to something also would alleviate issues with doubled naming
Or at least taking Options out from first Tools and making them a separate drop down menu- but that would still lead to mistaking one Tools for the others
Honestly, if you have such problems with the term "Tools", then you could change that in the language file.
Look for
_C_MNU_EXTRA
and change the following string.
(although I know that messing around with the language file is not recommended).
