Total Time
I would like to use an action to rename the directories for each cd to include the total times of All the tracks.
IE.
Artist/year-CD Name-Tracks-CD total time/01-track.mp3
                                                         /02-track.mp3
I know i can copy it from the bottom of the window.
chasonek
I think you have to run an export like this one first:
/t/17771/1
then you re-import the value into a file in that folder and rename the folder.
Or you create a format string for the Convert>Tag-Tag function to rename the folder where you enter the value that you read at the bottom in the status bar.
Maybe it can help, do have a look there ...
/t/12016/1
DD.20170413.1340.CEST
