%track% in xx/XX format
#1
I'm starting to play with the exports to see what I can do.
Is it standard that the %track% export placeholder always outputs in the format of xx/XX? Where xx is the track number and XX is the total number of tracks.
I was expecting %track% to give me just the track number, but I'm getting it in xx/XX format.
#2
%track% will return you exactly what you enterd as "Track"-tag in the file. So if the value was "12/20" it will return "12/20". And if the value was "12" it will return 12.
br
Chris
#3
Use $num(%track%,2) to get the tracks before '/'
#4
I thought that might be how it is. Unfortunately it seems that all of my files are in xx/XX format. They've been ripped using several different ripping tools and all of those tools have done the track tag in the same xx/XX format.
So I can't rely on %track% giving me just the track number and not something in the xx/XX format.
I ended up using a regular expression in the export script to clean up the %track% output.
$regexp(%track%,/.*,)
That strips away the "/" and everything to the right of it and leaves just the track number.
I have MP3Tag exporting an XML format file. Now I'll have to see what I can do with it.
#5
Hi
need some help with $regexp...
now i have track like xx/XX
1/10
2/10
3/10
10/10
But i want all with a leading 0, like
01/10
02/10
and also if
01/08 insted of 1/8
if i use
$regexp(%track%,(\d+),0$1)
the i will end up
01/011
011/011
Some one that knows these things?!
#6
$num($regexp(%track%,/.*,),2)/$num(%_total%,2)
or
$num(%track%,2)/$num(%_total%,2)
will do that. I only gave them a quick test. You'll want to verify they work with a variety of inputs.
#7
Well, I do it this way:
Begin Actionsgroup Format TRACK 'nn[slash]nn'
Action #1
Actiontype 4: Replace with regular expression
Field: TRACK
Regular expression: (\d*)/(\d*)
Replace matches with: $num($1,2)/$num($2,2)
[_] case sensitive comparison
End Actionsgroup Format TRACK 'nn[slash]nn' (1 Action)
DD.20080409.1146.CEST
#8
thx! great!
#9
More that one way to skin a cat.
I was assuming he wanted to format the export output rather than changing the actual value in the tags.
#10
but your was nice to have too! :slight_smile:
