Track Number (Keyboard Navigation)
I'm no longer able to click "Track" on the Tag List too add/edit. Can someone help fix? It's quicker and easier for me to manually add/edit rather than having to do it in the Tag Panel. Thanks!
I would use the track numbering wizard Ctrl-K to add track numbers to all the selected files
Are you talking about the File List (the MS Excel like table list)?
If yes, please show us the column definition for TRACK.
-> Right click on the column header, then "Customize Columns" and then please show us a screenshot for Value and Field. Both fields should contain %track%
Sometimes I need to manually track numbers when I only have titles within an album. Unless there's away the wizard can detect the order from some hidden encoding?
Thanks for your help. I needed to readd %track% to Field.
