How can I get the tag field just to show as track 5 listed not 5/10
Basically, I do not want the total number of tracks on the track tag
For example, Song Title: After All by Al Jarreau for the album High Crime is on track 5.
Have you tried editing the TRACK field? The placeholder is %track%.
Maybe the Auto-numbering Wizard would help. Give it a try. ![]()
Try Converter>Tag-Tag or an action of the type "Format value" either for TRACK
Format string: $num(%track%,1)
or if you like leading zeros:
Format string: $num(%track%,2)
