I am having a bit of a problem with merging a 2 disk album to a single album.
Part of the problem is that I don't understand how various players interpret the TRACK field that I can
see in MP3TAG.
So, the first disk has 12 songs and the second has 11 songs. I selected the second disk and modified
the track numbers using the following: $add(12+%track%). It worked, but it lost the total number of
tracks. That is the track numbers went from 1/11 ------ 11/11 and became 13 -------23. Basically, the
"/" and the track total were removed.
The question is how to get back the total so that the TRACK field would show 13/23 ------23/23.
Once I know how to do this, I will fix disk 1 to have tracks 1/23 ----- 12/23 and then, I think I can
merge the two files into a single album with the disk numbers removed.
I am supposing that I might add text "/23" to the already correct track numbers, but I don't know
whether or not the TRACK field is textual or really numerical. (I also do not know yet how to work
with text in MP3TAG).
