I've been playin with this for a couple days. I can't find a way to get just the original track number when using Tag-Filename. It keeps coming up with track/total. I thought I should be able to turn this off in the auto numbering wizard, but have not found it yet. Has anyone else figured this out? It's not a huge deal, the program is going to help out no matter what! Just thought I'd ask. Thanks: Dave
Use $num(%track%,1) in the tag-filename converter.
dano: Thanks, that works. Don't have a clue why, or how you figured that out! Anyway, thank you very much. Dave
