Tracknumbers (again)
#1
Hello all experts out there!
I want to number my audiobook files like "track number X" of "total number of tracks"
For example: I have an audiobook with 100 files and I have numberd the track field 001 to 100 already. Now I want my "title" field look like 1 of 100, 2 of 100, ......
Can I get any funktion tht will count the total number of tracks and then put that number in the Title-field so it looks like <1 of "total number of tracks"> ??
#2
If you have you files tagged with tracknumbers in 1/100, 2/100, ... format (you can use the Autonumbering wizard Ctrl+K for that), you can use a :mt_act: new action Format value with a formatstring like
$num(%track%,1) of %_total%
Best regards,
~ Florian
#3
You can also use the formatstring $num(%track%,1) of %_total_files%
with the current Development Build.
Best regards,
~ Florian
#4
Now I have tried to do like that. I doesn´t work :frowning:
My track numers become like "22 of 0"
the value %_total% or %_total_files% doesn´t seem to count the total number of tracks.
Any more suggestions? It worked half the way so the second half is coming soon, I hope :slight_smile:
#5
Did you try with the current development build as Florian said? Your profile still says 2.33.
Edit: By the way, %_total% works only if you have the tracknumbers in a format like "1/50".
#6
Now I have that. I will try again soon.
Thanks!! :smiley:
#7
Now it works !!!
Great, thanks alot for all Your help. :music:
