tracknumbers are always saved in v2
may it be possible that this old bug is back?
If I use the tracknumber-assistant, it always writes IDv.2 Tags, even if it woudn't be necessary.
Any ideas?
Regards,
    Flo
PS: I'm using 2.17f.
No, no ideas. Mp3tag writes no ID3v2 tags here, if the [color]ID3v2 only if ID3v1 too small[/color] option is enabled.
~ Florian
I have that option activated. It seems that it always writes ID3v2 when there isn'T already a v1 Tag and maybe sometimes even when there already is one.
Regards,
Flo
BTW: I have updated to 2.17i and the problem hasn't vanished!
Thanks for reporting. I'll fix that to the next development build.
Best regards,
~ Florian
