Traditional Chinese translation missing strings
As of Mp3tag v3.22, these are the untranslated strings for the Traditional Chinese translation of Mp3tag.
_C_CHECK Check
_C_MNU_EDIT_REDO &Redo\tCtrl+Y
_C_MNU_EDIT_REPEAT &Repeat\tCtrl+Y
_C_MNU_TAGSOURCES_SETTINGS Settings
_C_MNU_SB_EDIT_REDO Redo last undone operation.
_C_MNU_SB_EDIT_REPEAT Repeat last action.
_C_TEXT Text
_C_TT_EDIT_REDO Redo
_C_TT_EDIT_REPEAT Repeat
_C_WIZARD_TRACKS_RESETTRACK_NEXTDISC Reset track counter on next disc
_M_STR_EXPORT Export...
_M_STR_FIELDTYPE Type
_M_STR_IMPORT Import...
_M_STR_MANAGE Manage...
_M_STR_PRESET_SELECTION Create selection &preset...
_M_STR_SIZE_FULL Full
_M_STR_SIZE_LARGER Larger
_M_STR_SIZE_TINY Tiny
_M_UNDO_CANNOTREDO Cannot redo {1}
190213_Traditional Chinese translation missing strings.zip (958 Bytes)
Thank you! I'll include it with the next release.
