I have installed mp3tag onto a new computer.
Which folders/files do I need to copy from my previous mp3tag to keep the same actions, etc?
I did several searches for what I thought would be key words, and found nothing.
Thanks.
etg
Thanks.
etg
Installation & Backup
That should do it.
Im sure that would if I still had the old box and not just the drive. Oh well, Ill just remake the actions.
thanks anyhow.
IM,
look at the drive where you had MP3tag installed. Look for a file named Mp3tagSettings.zip - extract it to your new installed location, double-click the reg file, done.
