Is there a way to look for these chars and just drop them from the output stream on export only?
My importer doesn't like special chars even if supported by the OS.
Examples:
BEL BIV DEVOE - WORD TO THE MUTHA! - WBBD - BOOTCITY! THE REMIX ALBUM - 12 INCH VERSION
Need to drop the !
BRANDY - SITTIN' UP IN MY ROOM (DOUG RASHEED REMIX) - SITTIN' UP IN MY ROOM - 12 INCH VERSION
Need to drop the '
Parentheses seems to be no issue.
How can this be done?
Thanks
Chris
I've tried several iterations like:
$replace(%artist% - %title% - %album%,',).jpg;
But it still puts the ' in there on the output. i followed this _ > -. I'm trying to just get the ' to drop without adding a space. With this all I get on the output is .jpg nothing else.
Am I missing something?
Command: $replace(string,from,to) or $replace(string,from1,to1,from2,to2,...)
Example: $replace(%artist% - %album% - %track% - %title%,_,-)
This example replaces all underscores to dashes. You can provide additional pairs of from/to as parameters.
I figured it out, it was a special functionality character that I needed to add to disable raw parsing:
Need to add '' not just '.......reading the manual clearly helped!
Greetz
