Traxsource web tag scripts
follow up on the thread originally started here : TRAXSOURCE.com scripts - #24 by Wannastayunercover
I've decided to quickly make some Mp3tag traxsource web source scripts, and after late fixes ... here they are :
https://drive.google.com/drive/folders/1AXYwdbTNk9tuZh5EDuy6nWQxgcPfhjtv?usp=sharing
Enjoy.
Good job. I downloaded them from the other thread.
It's just missing cat no and the filenames would be better named with a # so they appear in the menu in their own group.
Traxsource#Release...
You can then add a keyboard shortcut by placing & before Traxscource like so &Traxsource#Release...
Then the subfiles can have one too.
Here's an example of one of mine:
Beatport by &stevehero v5.0#RELEASE Search by Dire&Ctory
The keyboard shortcut for this is:
Alt then S,S,C
Not using the release scripts which matches the info I get from traxsource since this very catalog number never gets provided in their single track info. fwiv
Updated with the latest sctripts I am actually using : Single scripts haven't been changed but the Release version got added padded tracks numbers/Total tracks and prices.
https://drive.google.com/drive/folders/1GgAKI8lOBrTERzhc_7o9u0sc3lxfBfc4?usp=sharing
Added track prices to Single searches too . Same link.
Searching via
  • Traxsource Release Direct by ID doesn't work for me.
  • Traxsource TRACK Direct by ID works but can't get album info tag.
If someone could check it...
hi! seems that the problem is the version 3.21b because i try a backup version of 3.21 and it works. so i hope some update wil be release about it.
@davedee Most of new files are on BP releases. However, it would be nice if someone take a look on link between Mp3Tag v3.21b and TS v0.2.
So, use new BP scripts by @stevehero until the TS script will be repaired.
Bug report here, don't think the scripts are broken. The SayRegexp fn is broken with its third parameter AFAIK.
The web sources have some significant problems, which will be highlighted when used with the latest Mp3tag v3.21d.
Moved to Broken Web Sources until someone takes care of that.
Hi Everyone, i dont know if this is the right topic but, until yesterday Traxsource source works fine with mp3tag 3.21 , but something happened and now it gives me back error "12152 WinHHttpReceiveResponse" so it dont recognise the request. anyone can update or fix this error on the Traxsource scripts? i know that beatport works well but i'm a traxsource user and most of music generes and tracks i find on Traxsource it doesnt found on beatport.
Thank U
Same error here, everything works fine until last week before update mp3tag 3.30 from 3.29 so I don't thing it is an update problem. I would try with an older version but there are not available to download. If you use 3.21 it's not an update problem for sure.
I use the track search as track direct doesn't work anymore and I found a problem with this line "regexpreplace "<div data-trid="([^"]+)"" "<><><TrackTrackID1=$1>"
If I understand well, the script use RegEx to find some strings in the code source of the page, but I think the source page on Traxsource has changed and the script doesn't work now. If I comment the line, i have no error, but not result also witch is normal. I try to search more but I am not developper, if someone can help me, I'll appreciate it :wink:
