How do I trim the filename to make it show only the first artist from a list of contributing artists ?
Example:
Original Artists: Alfa, Beta, Gamma Tittle: My Song
Actual filename: alfa, beta, gamma _ My Song
I want to trim the filename field after the first ( , ) to obtain this:
Expected filename: alfa _ My Song
Make a new action: "Replace with regular expression"
"Field": FILENAME
"Regular expression": ^(.?)(\s?),(.*?)(\s*?)([^\s])(.*)$
"Replace with": $1 _ $5$6
OK it's just that while your (impressive-looking by the way) explanation did not say where he should put it, mine explained that, too, and as far as I know it is a working solution, so I was just wondering if he ever tried it.
Are you a programmer?
I noticed you are good at coding but not always know how exactly mp3tag applies RegExp:)
Some of the stuff you write takes quite a while for me to see through (nice)
ok, I understand how to replace with regular expression. I just don't know what codes to use to do what I need to do.
I want to DELETE the artist name from the file name, and only leave the song title. my song looks like this
artist - title
I want it to look like this
title
I just do not know what codes to put in which places (I'm assuming it is a _filename, but I'm not sure on the "regular expression: and the "replace matches with" function should show. Also, a lot of these songs may not have the artist name in the id tag (is that the right word, hopefully you understand what I mean), and it would be nice to put it in the tag. If you could show me THAT, I would be eternailly greatful!
... or ...
Action: Format value
Field: _FILENAME
Formatstring: $regexp(%_filename%,'^(.+?)(, .+?)+( _ .+)$','$1$3')
To:
alfa _ My Song
... or ...
Field: _FILENAME
Formatstring: $regexp(%_filename%,'^(.+?), .+ _ (.+)$','$1 _ $2')
To:
alfa _ My Song
