Trouble importing discogs data
did you notice any change while importing data from discogs?
For some days I get error messages ("...keine Einträge für Suchanfrage...") for simple search requests (à la Artist: Moby), which worked fine before.
I am using Mp3tag under Crossover, but that should not be the problem, as it worked fine until some days ago.
Please give it a try and tell me if sth has changed.
Cheers
Martin
You can get updated scripts from here
/t/1681/1
Great, thanks.
