I'm trying to remove an extended tag
Action - Remove Fields
The metadata is this:
WWW <DIGITE AQUI A DESCRIÇÃO>
I can't get it to work
The action "Remove fields" remove any field of the given type - but not one with a particular contents.
So to remove all fields of the type WWW in all the selected files use:
If you want to apply that action only to files that have special data in a field, apply a filter first:
www HAS digite aqui
Alternatively, instead of the action, open the extended tags dialogue as described here:
