Troubles with connectivity to both MusicBrainz and Bandcamp
I've noticed in recent weeks that both MusicBrainz is experiencing overload and Bandcamp is timing out with a "Failed to authenticate" error
. The MB issue has been documented elsewhere but I don't see anything re: Bandcamp. This is occuring at least four out of five attempts throughout the U.S. ET day and evening.
Are these solely third-party issues. If so, is there a third option to use via mp3tag?
Thanks from a very long time user
mp3tag.exe 3.36.1, Win 64
Does the same thing happen if you try a VPN with a different country of origin?
The following information is the most current for MusicBrainz:
Maybe this is related to your "operation timed out"?
For MB, it could also be that you are querying a very large release. Or is it the cover art that is very big?
Thanks for following up. I don't use VPNs because of the lag. As mentioned, I've seen the explanation for MusicBrain, but not Bandcamp. The cover art is often a meg or less - standard. The errors occur even if there is no cover art.
Perhaps if there's a way to unauthenticate, reauthenticate Bc, I'd try that next.
The timeouts you're experiencing are different from the mentioned MusicBrainz 503 responses (which indicate a Service Unavailable error).
Have you tried increasing the timeout at File → Options → Networking?
Also, please make sure you're using the latest Bandcamp Tag Source where you search by pasting a Bandcamp URL.
