Hello
I have a folder on my desktop called jj
inside folder jj are 2 FLAC files, 2 JPG cover art files and 1 Text file called Exported_Tags.txt
The text file (Exported_Tags.txt) has the tag info for the two Flac Files
I'm simply trying to create an ACTION called IMPORT TAGS
which will import the Tag Info from the text file, from any working folder that has a text file inside it called Exported_Tags.txt
In the Action IMPORT TAGS I have added all the fields I want
and then under files names I have added %_directory%\Exported_Tags.txt
But for some strange reason Its not working
I get this error
Import text file "%_directory%\Exported Tags.txt": %ARTIST% - %TITLE% - %ALBUM% - %TRACK% - %YEAR% - %GENRE% - %COMMENT% - %DATE%: File C:\Users\john\Desktop\jj\jj\Exported_Tags.txt cannot be accessed.
WHY IS IT GIVING ME 2 \jj\jj\
If I just use %_directory%
I get the same error
Import text file "%_directory%\Exported Tags.txt": %ARTIST% - %TITLE% - %ALBUM% - %TRACK% - %YEAR% - %GENRE% - %COMMENT% - %DATE%: File C:\Users\john\Desktop\jj\jj cannot be accessed.
there should only be one \jj\ NOT TWO
I only have one folder on my desktop called jj, NO sub folders?
because this ACTION is trying to load the text file from \jj\jj\ is why I can't get access to my textfile via the ACTION
please help is this a BUG in MP3TAG ???
If I manually select the path to folder jj it works and imports the tags,
But I want to be able to use this action for any working folder with text file (Exported_Tags.txt) inside it
and thus can't due to the %_directory% not working and coming back with strange values i.e. \jj\jj ?????
what is going on ???
