I am noticing that there are two different kinds of single apostrophes (’ and ') that can be used in mp3 tags and that there appears to be no consistent usage and as a result it causes weird sorting results and is getting annoying. Are one or both of them legitimate punctuation-wise, and if so, how should I handle it? I'm leaning towards just picking one and doing a global substitution but I'm curious if anyone else has this problem?
EDIT: I'm assuming resolution would be to create 2 filters and 2 action groups...
Actually, you can use more or less any printable and sometimes even unprintable characters (like linefeeds) in tags.
So it is more in the responsibility of the editor to select the correct characters.
Right now, only one of them is actually an apostrophe:
U+2019 : RIGHT SINGLE QUOTATION MARK {single comma quotation mark}
U+0027 : APOSTROPHE {single quote; APL quote}
Here is a thread that deals with other similar looking characters:
Yes, this would be the best solution.
A possible way to replace the variations with just one character is also mentioned in the linked thread
I still think that a general replacement to get just one expression of the apostrophe is the best approach.
The unicode names only illustrated that these are in fact different characters and looking at the code number explaines why the would sort differently unless the programmer of the sorting algorithm hasn't included some kind of replacement internally.
And the fact that OP can’t even see the difference between the 2+ apostrophes unless he gets his eyes within 2” of his display makes using mp3tag filters+ quick changes a no brainer
As you can save filter expressions with Manage History ...
it may be worthwhile the effort to create that filter once and then recall it from history without the need to type it in with
Alternatively, a clean-up action group that also replaces all the variations of apostrophes with just the simple version would be an option.
Or you leave everything as it is and live with the differences.
