Two simple suggested changes (?) to improve efficiency
These are very simple things. Perhaps both are already possible. I'm using the Mac version. Both are simple. First, when I am finished working with files in a folder and I want to return to the main music folder, I always go back to the beginning of the file list--that is, if it's arranged alphabetically, to subfolders that start with "A" (or with numbers or symbols). Instead, I'd like to go back to where I was. If I was in the J's--let us say, Joanna Newsom--I'd like to be able to return exactly to that place in the file lis when I'm done working in that folder. I have quite a lot of music, so this main folder has many entries; scrolling back to where I was takes a good bit of time.
Second, I find myself using the "Replace" action very frequently. I access Replace with Option-Cmd-6 then typing the first several letters of "Replace." It would be great to have a keyboard shortcut to instead go directly to Replace.
If one or both of these things is already possible, please tell me how to do it.
I have very much enjoyed this program. I first started using it seven years ago, but I only use it intermittently, so I am not an advanced user.
Thanks very much.
Jim
