Hello, i have a problem while exporting. It exports only the first file tag from the list although all files are highlighted. I'm using standard txt_taglist.mte
Everything was ok previous, now it doesn't work.
Do you know the solution?
Many greetings
MK
What's the content of your txt_taglist.mte ?
[EXPORTRECORD]
RECORDLINE01=%artist% - %title%
[EXPORTSORT]
SORT=9
[EXPORTEXTENSION]
EXTENSION=txt
standard, nothing changed since installing.
You are using the old export templates. Read the help for more information how to create an export configuration yourself.
To make it a little easier, this is the new standard content of this file:
$filename(txt)$loop(%_path%)%artist% - %album% - %title% - %track% - %year% - %genre% - %comment%
$loopend()
You can replace the old lines with it.
