Hello
I am trying to understand what type to use . I seem to be digging a deeper hole after several hours of searching
I have took an mp3 album which has ID3v2.3 (ID3v1) ID3v2.3
I am not sure why are there (two) ID3v2.3 no ID3v2 or Ape
From what I gather trying to find answers; ID3v1 are less common where the ID3v2 has several benefits over v1. album art and additional information can be added.
I tried removing v1 tags and ended up with only the file name everything else went blank this would not show anything in the left hand side of mp3tag. The settings I used are in the 2 screenshots.
I use Aimp, MediaMonkey, and Winamp on Windows 7 & 10 when burning an mp3 to audio cd this would be used on hi fi separates cd player and on a car radio cd both with CD - Text support
What tags do I actually need, v1 v2 & or v2.3 or Ape
You may want to have a look at wikipedia for more details on tags:
All these tags are ID3 tags - but with a different version or purpose.
MP3tag understands how to handle them.
For your files I would recommend ID3V2.3 and ID3V1 - but no APE. V2.3 Tags are probably supported by most players.
APE tags in MP3 files are used by MediaMonkey to save replaygain data unless told otherwise. AFAIK.
Here is an example procedure how to cut APE tags - you will probably be able to adapt it to V1 tags:
Adding ID3v2.3 would be recommended for most compatibility, ID3v1 can be usefull for really old devices.
DO NOT use Ape Tag in mp3s because I may cause problems in other mediaplayers and hardware devices!
ID3 was desined for use in mp3 format, APE wasn't. Cause of that, media players that doesn't support APE (most doesn't do) can try to read APE Tag as audio data
(maybe it will just make some evil noice, but maybe player may decide not to play file)
