In a web script I am doing this per track
...snip... OutputTo "MOVEMENTNAME" json_select "name" FindInLine ":" SayRest Say "|" ...snip...
But on the next pass, the last letter from the previous is added in front of it.
Eg. First time it is correct: "Allegro", but the next one becomes "oAdagio", then "oFinale".
I found a workaround, by adding a space after the ":" it works properly.
I'd need a minimal working example if you think you've found something worth investigating. It's expected that FindInLine also works with single-character find strings.
FindInLine
