Can I get or set the MP3 Unique File Identifier (UFID) with MP3tag ?
I guess I've set it with a Java program I just wrote, but I don't see it with ALT-T ?
Nope. This frame is currently not supported.
Can you send me one of the files to my contact mail?
Best regards,
~ Florian
I will once I figured out how to correctly write one... my Java program still seems to be causing some troubles and is corrupting my MP3 ![]()
Okay, so no file needed ![]()
It seems like the MusicBrainz Tagger stores information in the UFID frame.
I'll have a look at it.
Best regards,
~ Florian
The latest Development Build supports this frame now.
Best regards,
~ Florian
Great... this works fine ! (even with multiple frames). I can read it fine in Java now, the only problem is the Java library corrupts the file when I try to set it (but that's nothing you can help with).
Happy New Year !
It's not even New Year... and I'm dreaming of a next tag already... the MCDI
